I’d have to respectfully disagree with the front taking/needing better dampening than the rear.
When the front hits something, it will have to deal with that hit, when the rear hits something, it has to deal with the same bump AND the force of the truck that wasn’t absorbed by the front shifting to the rear.
Also, the rear shocks are laid over to almost the same degree that the fronts are, so travel characteristics are the same. That’s the biggest rear suspension advantage the 200 has over the Tacoma/4Runner/FJ/Tundra as those rear shocks are vertical and are more like
@bloc described.
For tuning, guys like
@cruiseroutfit are going to be the be able to offer the real low down, so Kurt, what say you?
For me, and my past if living in West Texas with both a long traveled FJ and a 200. I lowered the front nitro charge from 290 psi to 270 psi, and with a winch bar, winch, and stainless steel skid plates, and am at C4C3. (See
@TeCKis300, I like it soft if I can, but that means my payload has to stay constant)
But for my rear, I bumped nitro pressure to 305 psi, and run the BPs at C7R6 with a 2723 and only camping gear in the back.
When I ran across those long West Texas tracks that are just like Baja (I’ve been) my front doesn’t rock force to the rear, and the rear has the additional dampinging ability to stay flat and keep the front end down.
I’m not going to lie guys, when my rear axle hits anything at speed. I know the rear axle is cycling hard... but guys I swear, the frame stays perfectly flat, it’s perfect. I will say, the redesigned front BPs need less preload than the first run, so I need to bring that down a tad, but it’s quite smooth.
