IACV inspection/ operation/ valve movement
devo
NoCo
Following the FSM inspecting the IACV
How much movement should there be with the valve. The dotted lines in the illustration suggest that the valve should move a centimeter or more?
Or fully retracted to fully extended.
Barely visible movement on each pulse, I used a digital caliper to measure change. A dial guage in a fixture might be better, Mine was buried or I would have used that. As more knowledgable people have posted it is a multi position stepper motor and each step is only a partial (1/4 turn maybe?) rotation. The part that moves is riding up and down a screw inside the housing, the travel distance per pulse is miniscule.
Since the start of this thread I have put 3 AICV through its paces. I never measured the distance the plunger traveled and I have forgotten how many pulses it takes for the plunger to have gone from full extension to full retraction. I do know that 2 used AICV and 1 new all acted the same on the bench. I know the new one acted differently when installed and the ECU took over operations. The idle speed dropped to near 625 rpm!
