A couple days ago I did a valve adjustment and set my timing. Only problem is I was really down on top end power* when I took it for a drive. So I played with the timing a little and after a few test drives I got the power improved. Then I put the timing light on it and my baseline timing was set at 15 degrees, and that's in addition to the 7 degrees accounted for the the ball-bearing. I have no pinging at any RPM/any throttle.
This leads me to believe that my dissy is not advancing like it should.
My question for you guys is: what should I do?
*I have operationally defined "top end power" by my cruising speed with the first barrel wide open.
