I ordered the wrong OEM 2F Water Pump. Anybody need the non oil cooler pump?
So. Austin, tx
I ordered a new water pump from ToyotaPartsZone and installed it on the 2F. It is the wrong pump. I need the short shaft with oil cooler since the motor going into the 40 is not the original. I cannot return it cause it sat in my garage for a while.
Anybody need a long shaft pump? I installed it on the block which is still on the stand, so it is still new. Just order me the correct OEM pump which is around $55 cheaper than what I paid for mine.
Here's what I ordered... 16100-61012 - OEM Toyota PUMP ASSY, WATER
Here's what I need... 16110-61081-77 - OEM Toyota PUMP ASSY,WATER
Thanks,
Luis
10-4, let me know...
No picture on the links, was wondering what yours looked like. I ordered one from some place else and it had the heater return on it, where as the one I took off of my 2f didn't have it. I blocked that return off as the lower hoses has a spot for the heater return...guess I'll find out soon enough when get it back together...
I got the one on the right, after I posted I went home and compared the two I have, low and behold, I got the correct length flange. Mine is a Gates, got from Rock Auto for a little over $17 I think.... I'd have to look at the receipt again..... came with the gasket and studs.
W.L, if you bought a Gates water pump from Rock Auto for $17, you made a major score. :cheers:
The only Gates pump they have listed now is $57. At $17, you should have bought a case and re-sold them at C&C for $50 each.
I need to look at the reciept again, but it was rediculously low because other places I tried was up to $80.00 - $60 something being the cheapest
I was thinking the same thing...
