I need some advice on a shackle problem
Discussion in '60-Series Wagons' started by dfcruiserguy, Jun 21, 2005.
  1. dfcruiserguy
    dfcruiserguy
    113
    Jun 21, 2005
    Irmo, SC
    I got stuck in a big creek bed for awhile today before my friend nathan and his 40 pulled me out, on the way out of the woods i hit a big bump i didn't see and i was goin a good 20 when i would've crawled over it. I'm not sure if it was the odd positioning in the creekbed or the bump but I noticed i was leaning when i got home and discovered that the rear left shackle has flipped itself so that it is snug against the frame pointing towards the rear. Does anyone have any advice as how to fix this problem in a manner which doesn't involve taking off the tire and u-bolts and plate and all?
  2. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    jack the rig up
    so your suspension drops(high lift will work for this,if you dont have one now is a good time to get one)
    raise up the corner that the shackle has inverted.
    it may drop down, or you may have to push down on the tire.
    lift it high enough to get the tire off the ground.
  3. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    Get a big pry bar and flip it out..
  4. dfcruiserguy
    dfcruiserguy
    113
    Jun 21, 2005
    Irmo, SC
    thanks guys, as a poor teen i don't have any cash for a high lift but my good buddy nathan does and i'm sure he'd let me borrow it for this, when he pulled me out today he also recommended i get one, so after i get the carb fixed i'll invest in one
