Ok, so the first charger I returned was a NOCO, I don’t remember what size, got it from Wally World for $225. My battery was actually not at 0, but close enough that I couldn’t even unlock the doors with the key fob. When I used the key and op0ened the door, the alarm sounded, so the batt must have had some charge, I guess. However, with the NOCO connected, it would not budge, I couldn’t get anything, not even the ignition chime. My neighbor connected his NOCO, which was a larger one, and nada. We then connected a larger shop charger and actually left it on for about 3 hrs, give or take, not one. The battery was two months new, Autozone Gold. So, I guess I’ll try and exchange it. Mayb they’ll exchange it, mayeb they won’t.
From what little I understand about the lithium batteries (hardly anything), like this LifePro one you suggest, the battery has to be completely charged before being used. This means using a compatable charger and waiting until the batts 100%, ready to go. I’m guessing this means charging it uninstalled, with a stand alone charger? Once this is done nd installed, I’m guessing then the batts good to go from that point.
On the NOCO, which size should I buy? I’m skeptical, since the first one did’nt work. Any suggestions on who to buy the LifePro from? Is there a box store who sells them, or online only? It would be nice to receieve one already fully charged, ready to install and use. Thanks!
To add…I just read that one must use a charger specifically designed for this battery. I’m not seeing anything about LifePro being used as a starting battery, as in common vehicles. I’m not sure how to reference the LX in order to buy a LifePro.
