I just bought some Method 305 NV in brozne (2 Viewers)
I ordered these the 18” nvs and i canceled the order due to not wanting rubbing issues in the future. I have a 3” lift and run 16” oem wheels with spc uca i find it hard to believe no one has had rubbing issues. After dealing with rubbing issues with my toyota tundra i decided it was not worth the risk. 2500$ later to have issues no thanks . Just my opinion. Many people seem to run them with no issues so take my opinion with a grain of salt
Thanks for the quick reply, do you think you could stuff an extra 1.6" of height and 0.5" of with on those? I wouldn't mind minimal rubbing at max articulation in the rear. Could solve that with some spacers for the bump stops. But if the only path is through the fender.... then I might have to stick with the safe tundra 5 spokes I have haha Brandon12777 pictures look like the front might be hard pressed to stuff a bigger tire.
I think so and im so confident im going to a larger tire size like the one you mentioned when its time for new tires.
@Biga27110 and @FxFormat are you guys both running 18x9 +25 or 17x8.5 +0?
Also, what suspension/lift are you running?
Curious to know if you guys flattened the pinch welds or modified the plastic liners etc?
18's and no fender mods
^^^ yeah what he said.
+25, no rub, no fender mods, i just shimmed the rear springs with 30mm coil spacers and cranked the stock TBs about 1.5"
Did it too, Looks amazing.
They are MR 305 18x9. Tires are 305x65x18 Falken wildpeak AT3 W/S. No rubbing thus far.
Hole saw, drill a pilot hole dead center, then use the hole saw. Make surento drill from the back side or the method logo will fall out.
If your anal, you can spray the dust cap black like I did.
Method could make a small change to their center cap and extend the center section out 10-15 mm then it wouldnt require drilling.
You can also order a longer cap
which one would the be long enough id hate to buy the same short length.
I am looking at getting a set of these and mounting 315/70r17's on them. I have an OME lift and plan on doing the pinch weld mod. Do you guys have back-spacing recommendations for the 17" rim?
A dude near me has 4 of these in black with falken at3w’s in 295/70r18. 95%!tread life estimated. Asking 1850$ but I can get the rims I really want and tires new for that.What do you guys think is a Fair offer?
