Had a look at mine and it's only got 2 loops in the resistive coil, compared to the items for the B motors shown above. Not sure that it's ever worked, the coil still has dune beige paint all over it, the nuts are rusted up though.
Couple of questions here, are the controllers still available new and does the H diesel use the same 8.5 V plugs? (but 2 more of them) The controller on mine doesn't work and erm......there's bare copper attached to one of the terminals. That's kinda bad.![]()
You will need 240mm of B&S 15 (1.45mm) nichrome. Form over 8mm drill bit, 6 loops.
Hmmmm. The combination of 6 parallel-connected plugs would have a lower overall resistance and thus would promote higher current flow through the glow controller. So I guess this would tend to burn out a 4-cylinder controller. From this line of thinking ....I guess a 6-cylinder controller would need thicker wire (or less turns of wire) in order to produce the SAME voltage drop from the higher 6-plug current.
...Well, that's curious - I have the fully-enclosed controller (new as of last year) on my truck Tom, and it glows just as bright as yours.....
Wow! Are you sure Alex? Is that length, type, rating, and no. of coils accurate for a "12Volt 6 x 8.5Vplug cruiser?
Of course a 6-plug engine must require a different coil resistance to a 4 cylinder. And I'm trying to get my head around this.Hmmmm. The combination of 6 parallel-connected plugs would have a lower overall resistance and thus would promote higher current flow through the glow controller. So I guess this would tend to burn out a 4-cylinder controller. From this line of thinking ....I guess a 6-cylinder controller would need thicker wire (or less turns of wire) in order to produce the SAME voltage drop from the higher 6-plug current.
If you have this sort of data at your fingertips, can you give us the same details for our "12Volt 4 x 8.5Vplug versions"
PS. I understand our BJ40 controllers glow more clearly/brightly than the more-enclosed BJ42 controllers (where four 8.5V plugs are also used .... in BJ42s that date from around 1980 to 1982).
And nanocr87 sent me a photo of his BJ40 controller glowing just as well as mine does (once he got the right plugs fitted).
PS. The reason I'm quite fussy about the Brand of glowplug I choose for my BJ40 is because I know the resistance of my glowplugs MUST match my existing glow controller properly. Too much resistance and it won't glow brightly. Too little resitance and it is likely to melt.
I think cruisers with other types of glow systems may not be so sensitive to having "OEM spec plugs" --- and so their owners can probably experiment more freely with cheap plugs that are sourced from emerging manufacturers (without such a high risk involved).
PPS. Great thread...............Lots of good stuff here.
...this entire thread leads me to wonder how many people are driving around with the wrong glowplugs in their truck....
... I would thing that Falco80 and his slightly lower voltage plugs, with all glow plugs firing, would have a controller glowing very red very fast.![]()
Sorry, that's what it would be for our BJ40's Tom, just realized herbs has a 42.
The way I worked this out was by measuring the thickness of my controller resistor wire and cross referencing a B&S nichrome wire chart. Then I formed a similar coil out of copper to work out the total length and checked that the resistance would match, which it does, 0.05 ohm (you'll need a good meter to measure this).
I wonder if the wrong glow plugs have been put in and it's cooked the terminals on the controller?
...There's been a serious amount of current applied to it at some stage because the insulation of the wires on it has burnt off...
Well, if your truck was made on 10/82 or later...
Noob question/thread hijack: where is the date of manufacture on the truck? My vin plate is in good condition, but doesn't list it. There's a silver sticker inside the right door jamb, but it's completely blank. Is there another plate I'm missing?
