Edit - I got it out!
Details on page 3: link
Thank you to everyone that commented!
------ How I got the cap out -------
Suggested tools: shop vac with a 1 7/8" hose and some motor oil
Drain all of the diff fluid out
Fill the diff with motor oil
Turn on the shop vac
Remove the drain plug, and plug the hole with a finger
Remove finger from the drain and quickly cover it with a 1 7/8" hose of a 5hp shop vac or something close, but don't insert the hose in the drain
Check the shop vac bucket
The 1 7/8" shop vac hose fits perfectly to the protective ring around the drain. This is extremely helpful in creating a good vacuum and not obstructing the outflow from the drain.
Original post:
Yes, you read that correctly; I accidentally dropped the cap from the diff fluid in...the rear diff. I was trying to see how I'd approach getting the fluid out of the bottle and into the diff when I quickly realized the cap was missing.
I tried to locate the cap using a USB Snake Inspection Camera, but I've yet to find it and will try again in the morning.
How would you go about retrieving the cap?
Original post:
