Aussie
I just put an Aussie in the rear of mine last wkend. I kind'a took a different route than most. I bought 2 FJ 60 front 3rds, which gave me 3.70 gears for the hiway, fine spline pinions, and less wear than my '77 3rds have. An SM 420 is in the future for my low gear option. After installing, I drove it to work this week to get a feel for how it would handle. Since I used a front 3rd in the rear for the Aussie install, all my clearances that you check as you go allong, were on the min side. I've only heard the cliking a few times, had it lurch to the side a couple times when making a tight turn into a parking space, but really noticed the tourqe steer when gassing on it going thru the gears. I had read on Mud where someone had added limited slip fluid to his, and a buddy hadn't, and he didn't have near the popping and banging his buddy did. When I filled mine up I used that " trick ", so maybe it does make a difference. Good luck, Al
