HZJ77 rear light bar removal
Anyone know how this comes off? I failed inspection because it doesn’t work. RM183E doesn’t cover this which is usually the case for anything HZJ77 specific.
Disregard. I figured it out. Outer cover snaps off. Thank goodness I didn’t have to mess with headliner.
I need to check if mine works haha. I hate messing with the head liners. I replaced the hatch on my fj80 and had to pull the headliner down slightly in the back to get the wiring through. it was very difficult to put back.
Fortunately you don't have to mess with any headliner for this specific task. The outer cover just snaps off which is held on at two points by a pin like metal rod. One side was rusty which I assume was from moisture seeping in as the cover itself doesn't really keep out moisture.
One other thing. The red light assy which is a sealed unit is over $300 new. P/N: 81570-60040 It isn't a matter of changing out bulbs in this case.
I may be missing the obvious but do you have a bulb or wiring issue?
Not too sure. Don't see anything wrong with the wires. I thought it was working again but then it stopped working.
Good info. Thank you. On my to-do list too.
Definitely order a new gasket/housing unit and new outer cover befoe you do this. The original pieces are brittle from sun exposure and needs to be replaced.
p/n: 81572-60050 GASKET
p/n: 81977-60060 COVER (comes in different colors, I opted for black)
Above photo stolen from here: センターストップランプリフレッシュ(その1) 項目8|ランドクルーザープラド/トヨタ|整備手帳|78ウルフ|みんカラ - 車・自動車SNS(ブログ・パーツ・整備・燃費) - https://minkara.carview.co.jp/userid/1969936/car/1479716/4338482/8/note.aspx#title
Good call. Have the gasket.... I'll get the cover on order.
Hello,
Are these LEDs?
Juan
based off what led light strips look like, I am going to say no. It is A long thin circuit board with little bulbs soldered in a row, whatever that is called. I am no expert on lights though.
