thanks ill go check have a check now i got the RH drum off as we speak...
it seams weird tho as i haven't changed the setting of the bell crank when i replaced shoes ,slaves and springs a month ago .
it was was working fine up until then , brakes worked ,e brake worked , funny considering that there was no pad left ,there was a major fluid leak and the cable pin on the bell crank was rusted in..
bell crank was pulled apart and cleaned installed with new boots..
the only things that i haven't replaced was the auto adjusters and the cable between the shoes .. i have new ones now to put in now tho....
any way ill go have a look and ill get back to you in a bit... thanks again
