Build HZJ75 build in US
I do know that they have to be 25 years or older to import to the US I hope I can register it
I got the spring perches all welded on to 75 width today but unfortunately I forgot some parts at work and couldn't get the axle 100 together tonight should be sitting on a rolling chassis by friday
Got the inside all cleaned out too and vacuumed up. Found a couple interior parts and hood cal :D and got the surrounding area all cleaned for room to work!
That looks a bit like my old body, is there much rust in the foot wells and the wheel arch inners?
since the frame is a 94, i'd drop in a 1FZ. That engine on the 70 series is awesome and should be a direct install right?
Where I am located I couldn't get one without signing my life away to buy it :( I wish maybe one day for now 2f is the route
The vin under the hood says the 1hz and h55f so I assume not? And not bad! But they do need some love for sure
It's been awhile since an update so I will give one now! I have been busy and kinda lost sight of the build almost sold it but have decided to take this build in a whole different direction. Since the frame is so bare is had thoughts of different ways of building. I am picking up a fj60 that was rear ended for 200 dollars. The axles are missing which is no big deal because I have a set. So I am going to pull the cab off and put the cab on the 60 frame since I was going to run all 60 drivetrain anyways it will work perfect. It's probably going to get a spring over haven't decided yet. Interior will go all 60 even down to the dash. And it will get a custom tray back and sit on 35 inch tires. Thoughts?
Has anyone ever seen or done a 60 interior in a 70 series? Do you know if the dash will bolt in??
Motor is coming together for this truck! Super excited to here it start up!
Rear axle is all put together with some fresh paint and tires. Too bad I need to remount the perches back to 60 series width!
That's a good move going to the 60 chassis as you have access to a lot more bits. I have seen some 45 cabs on 60 chassis.
Most of the chassis converted 75s in Aus go onto 80 series chassis, 1 the 75s here are complete and on leafs ,and 2 for the coils but I'm sure that would be a fair bit more $$ going down that path
35s and a SOA would look boss there is plenty of tray back pics on the Aussie forums and they are not to hard to make.
Thanks for the info! I appreciate it. Are the 60 frames a lot shorter then the 75 frame? And spring over would be awesome!
