HZJ73 Axles - upgrade those Pig axles!
The Woodlands, Texas
I have a pair of HZJ73 axles for sale in the Houston area.
The rear axle is full floating and both axles feature disk brakes. Factory rear e-locker and electric locking front hubs. These axles are a great way to upgrade your old drum axles to disks and you get a sturdier full floating rear, factory locking rear diff and electric front hubs in the bargain. The axles are 24v so you will have to obtain a voltage converter to use them on a 12v system (I have one I can sell you).
I will palletize them but you will have to arrange pickup and shipping from ZIP code 77382.
$2000 for the pair.
I'll try to get some pics up soon. The front hubs have flat surfaces with no manual knobs or anything. They are engaged remotely with a switch.
The spring perches would need to be moved for use on an FJ55.
Doesn't the front also have an e-locker as well?
Having helped ole pig boy move these heavy bastards a couple times, I can vouch for the excellent shape thay are in. The front also has the tie rod and drag link attached as well.
Good luck Patrick,
Buck
Could swap out the motors for twelve volters or turn them into cable lockers, killer set of axles for the price.
