HZ HD-T Starter 28100-17010 28100-17040 replacement
Tucson
there is a bit of info regarding replacement(s) for "early HZ/HD starters".
I'm simply adding to the possibilities.
starter(s) for the Yanmar 6LP variations are a DIRECT replacement. no nosecone swaps, no voltage discrepancies, 12 tooth Pinion in a 2.5KW
generic part # 410-52134
and at $138, I'll just keep one on the shelf, 1/2 a banana-45 minute job max
early??? not sure what the difference is 1HD-FTE
I will run the numbers when I get back in front of a computer, but I am pretty certain the only discernible difference is with the ignition lead terminal on the solenoid.
Since many owners don’t like surprises, I was trying to keep the info to “plug and play”
'90 HD (80 series) through '92
28100-17010 Starter Assy 12V 2.5kw *superseded # 28100-17040
28115-17020 Housing (nose cone)
28011-17020 Clutch (w pinion gear)
28150-17010 Solenoid
'96 HDFT (80 series)
28100-17030 Starter Assy 24V 4.5kw *superseded # 28100-17050 *Bangladesh 28100-17020 12V 2.5kw
28150-17030 Solenoid ('92-'96) 28150-17050 ('96-'97)
'01 HDFTE (100 series)
28100-17070 Starter Assy 12V 3kw
28115-17070 Housing (nose cone)
28011-54010 Clutch
28150-17070 Solenoid
'06 HDFTE (100 series)
00000-00000 Housing
28011-54010 Clutch
awsome list thanks for sharing!!!
