Like a bunch of us, I want to run 16" wheels on my cruiser. In measuring the wheels that I have to install the clips for the hubcaps I realized that pieces commercially available would not work. So, being a full time blacksmith and metal worker I am considering manufacturing these clips to work with the New style 16" Tacoma steel wheels and possibly the 17" steel wheels as well. My version of the clip is made with a heavier gauge 15n20 steel. Formed, heat treated and annealed. These are slightly wider than the originals and the bends are not as shallow, while keeping the proper shape, these will not suffer from the work hardening and cracking of a sharper bend. Each clip is shaped individually and have 2 mounting holes instead of the single on the factory versions. This will allow them to be placed into a wheel with more backspacing while keeping the proper height for the hubcap. Two connection points will also stop the clip from moving on the flat inner surface of the wheel. This will allow you to spot weld them in place, bolt them in or use a stainless steel pop rivet to secure them. I can also provide dimensions for drilling the new wheels for the clips if needed. I will be making two or three versions of the clip to be used with the different steel wheels that are available. The first will be for the 16" tacoma steel wheel that is the most popular. The second will be a heavy duty replacement for the OEM clips and the last will be for use with the 17" tacoma steel wheels at some point. I want to keep these as inexpensive as I can but they are labor intensive to make. The pricing will be as follows. 6.00 per clip in raw steel. 7.00 per clip in self etching primer finish and 8.00 per clip in black or grey powder coat. Turn around time will obviously be longer on the powder coated clips as I will need to send those out. The others are finished in house.
