you are OBDII then
If you want to hold a auto trans crank shaft. You can use a 1/2 inch extension 6 " long to hold in place the drive plate for the torque convertor. You can access this through the area where the plastic is at the back of the engine, between the oil pan and the trans. If you use the female end of the extension in the big hole in the plate(about 6 of them). and the male end toward one side of the aluminum housing of the oil pan. This will hold the crank in spot to either remove the crank bolt or to install it. Not my trick, so other mud member. I do use this trick a bunch.
on later 1fz engines with the crank position sensors(OBDII ones). The drive gear for the oil pump is not keyed. But the eariler ones with out OBDII are key slightly. So the potentinal for the oil pump to not turn if the bolt is not tight enough is a concern.
Is your engine in OZ a obd 1 engine or a OBD II engine?
If OBD II, I would recommend that you put a torque wrench on it to make sure it is close.
Why did the other poster say that the ribbed side would sit against this? It doesn't.
