Hello all,
I recently filled the body panel holes in my 80 series, so I figured i'd share how I accomplished it. This may not be the cheapest way, but it will deliver great results without worrying about panels warping due to welding heat. The panel adhesive is the same stuff your door skins are held together by.
The overall process was pretty simple:
Backside of fender prepped:
Lord 110B:
pieces of metal prepped:
Pieces adhered:
- Clean the backside surfaces of the panels you want to fill with some sort of wax and grease remover
- i used Dupli-Color
- Cut pieces of steel for filler plates
- i used a piece of 1" x 1/8" x 3ft section of steel from the hardware store
- Prep pieces with primer
- **Adhere the pieces in place using panel adhesive
- i used Lord Fusor 110B (note: you'll need the application gun)
- there may be other panel adhesives (or sizes) available that do not require a special gun
- one large tube of this will do the entire truck
- Fill with body filler (I used 3M filler)
- one quart of body filler should be plenty
- Sand smooth with 80 grit, then 180 grit
- may take multiple coats depending on your skill level
- Dura-Blocks are fantastic for this
- Prime and sand surface
Lord 110B:
Pieces adhered:
