lacruiser; think I'm headed for rebuilts, tried it when they were still in the rig and only a couple of them moved a little. The experienced mechanic who was helping me try to get the pistons out said they should turn some with a large pair of pliers and they didn't budge. He also suggested remans.
Called half a dozen parts stores, most could not get them for a few days, found one set at Autozone, Fenco brand, never heard of them, wasn't impressed. O'Reillys will have A1 Cardone remans and the lines in the morning, will check them out.
Newb question: how do I disconnect the soft lines from the hard lines without damaging the hard lines? I have a 10mm brake line wrench, not sure which way to twist it while standing in the wheel well. Like if it if lefty loosy from inside the frame rails, does that mean I turn to the right from standing in the wheel well for the driver's side?? And for the PS, do I turn the wrench toward the center line of the vehicle because the hose is mounted front to back. Does that make sense? After I get the hose disconnected, just pry up the clamp that holds it in place, any special tool or technique for that, just grab it with pliers and yank?
