On a CT 26, I have the stock Supra Waste gate actuator mounted (see post today in this section)...am I correct in assuming you can adjust the boost, by setting the preload of the actuator? I'm thinking of splitting the actuator arm, threading the ends, then using a turnbuckle style affair to effectively lengthen or shorten the rod, changing the preload...
am I way off base here??
