^^^Un-modified yes.
And it is a really good idea to modify with the center diff. lock switch. If you grenade your front diff., like I did, you can still pull the axles and front driveshaft and drive a couple hundred miles home.
^^^Un-modified yes.
My rear diff won't lock (factory lockers). Front locks fine, center locks when in low like its supposed to but rear just blinks and blinks. Any suggestions?
Check to see if it's actually engaging or not. The switch on the axle housing may be bad, and there's an alternate part number off a Camry or Carolla that will work for half the price. The locker may be engaging, but the light just flashes. That's what mine is doing, I just need to get off my duff and fix it. Ten minute job apparently.
Good call I'm not sure actually. I don't think it's engaging. How do I know 100% if it is or is not?
