For the techstream techies...how is the abs activated? I went to the abs ecu but so many options... Which one is it?
Oooooo, crap.Thanks but my issue is the brake pedal still seems spongy after the bleeding process. The reservoir ran out of fluid so I'm thinking the abs needs to be activated to remove air that could have gotten trapped there...
Whoa there buddy! I didn't really give a procedure.Taco2 I will give your procedure another try. Maybe I just did it the wrong way... Again thanks for sharing this procedure ....
Unless these MCs already come ench bleed?The section 2 instructions on bleeding the entire system using Techstream are supposed to be used when replacing the MC. That section is linked to from the Installation portion of the Hydraulic Brake Booster section (which includes MC replacement) in TIS. You shouldn't need to bench bleed.
