For Sale Houston, TX: PTO Box and PTO Winch (off a LJ78 but could fit other models)
Brunei
  1. 40 Series
  2. 60 Series
  3. 70 Series
My LC is sold, so am selling my PTO winch set-up: OEM PTO box, PTO Winch, spare pillow blocks shafts, drive shafts and yokes. Will also throw in a set of new U-Joints I have lying around. Had it mounted under floor on my LJ78, rear mounted with front line pay-out; To make it front mounted again, the worm gear in the winch housing and the PTO output shaft can be reversed (easy job, just do the inverse of my build here). Not sure what exact model it all came from, could be a mix of parts from 40, 60 70 series. Pulled it after a trip, so parts are a bit dusty.
Selling as complete set, asking $1200. Pick-up in Houston or freight organized by buyer.
Winch, front facing view
PTO box, rear view
PTO box, front view
Assorted Shafts, top one is the one what I was between running between PTO Box and Winch (note the extension weld in the middle). The others are stock I had as spare.
Some more photos of the winch:
Rear View
OEM Roller plate and top guards (did not use in my build)
Custom sewn cover. removable (combo of press buttons and velcro). Since I was running my winch under the car, I had this made to keep the dirt out when not in use.
6 spare Yokes (2 photos from different angle to show which are spline and which are smooth bore)
Bottom left yoke is the shear pin yoke I was running.
Same yokes from different angle
spare shear pins
I could not get hold of an original PTO lever so I fab'ed this one to mount onto the 1HZ gear box I was running. The lever has a pick-up brake light switch that I had wired to activate an under body rear view camera.
winch has its own wooden box for shipping. PTO box (in a cloth bag) and shafts (plastic wrapped) don't.
Also includes 6 new-in-box u-joints. More than you can ever break!
Am also including a free PTO take-off gear for inside the T-case. My HZ T-case on my LC already came with it, so I did not need to use. Bought 2nd hand and it already had surface rust. If you can find a new one, better to use that. But this will do if you de-rust and surface treat it.
Still sitting in my garage... Am moving house and don't want to lug it around. Price drop to $1000 if someone comes and picks it up in next 3 weeks. After that, price goes back up and I'll start looking for a cruiser to build around the winch.:rofl:
You should duplicate this ad in the Diesel JDM sales forum.
