- Year
- 1981
- Vehicle Model
- Minitruck
- Location
- Array
- Mileage
- 65000
- Color
- Yellow
*EDIT 12/2/21*- OPEN TO ANY REASONABLE OFFERS
1981 Toyota Pickup 4X4
Original paint
22r motor
Odometer reads 65K but it only has five digits…
5-speed (L-series I believe)
Power steering
5.29 gears
Custom rear driveshaft
Trail Gear front drive shaft
Lift
General 35’s with plenty of tread left
Weber 32 carb with LC Engineering fuel pressure regulator
Has AC but is not hooked up
E-brake does not work. I assume it is simple, I just haven't had a chance to look in to it.
Installed in the last 30 days:
Radiator (Davez Offroad oversized)
Thermostat
Water pump
Fan clutch
Hoses
Fuel pump
Fuel pressure regulator and fuel lines
Valve cover gasket
Spark plugs
Idle Cutoff Solenoid
Air filter and valve cover breather
I’ve also gone through and cleaned this thing up a lot, as well as address some of the crazy wiring that it had.
Not sure what the center console came out of but it works well. I also made the shifter plate to cover the hole in the floor that was there when I got it. I used ABS plastic
There was/is some rust on the frame, but it is just surface. It does have some rust on the body that would need to be addressed if you were to daily this or take it on as a full restoration. Couple spots rusted through on the cab, as well as on the bed in the usual spot under the lip.
Located in Houston, TX
$10,000 obo
Ted- 713-851-4755
Original paint
22r motor
Power steering
5.29 gears
Lift
Thermostat
Water pump
Fan clutch
Hoses
Fuel pump
Valve cover gasket
Spark plugs
$10,000 obo
Ted- 713-851-4755
