Mounted one on brother Rob's '97 today. Found a 14" at Auto Zone sold as a TorqFlow brand for 69.99, did a little research and it's a Derale #16514,
http://www.derale.com/electricfans.shtml great price for that fan!
This is the biggest fan that will fit, it's a squeeze but only required bending one tab out of the way and bending the horn mount slightly to clear. Had to pull the right headlight, fan and clutch, the right side and left upper radiator bolts so it could be pulled out on the right side to get the zip holders through the condenser. We bought an extra pack of the zip holders and used six with the supplied foam pads on the radiator side and put 3M double stick foam tape on the fan to keep it from shifting, it's not going anywhere!
Wired it up with a 25 amp fused wire from the battery to a 30 amp relay mounted between the washer bottle and aircleaner duct on the fender well. The relay is turned on by power tapped from the A/C clutch, so the fan runs with the compressor.
The total cost was about $90, it made about a 10 degree difference in the idle vent temp sitting in the shop, we will see how it works in the real world.
Auto Zone box label.
