Horn relay for 05LX470
Canada
Removed engine room junction box and tried to replace horn relay. Those identical black relays are welded to the JB and they are DENSO 156700-1081 with 12V relay. Checked around the internet but couldn't find this kind of relay. Any suggestion and information?
same here. has anyone found the replacement relays for 156700-1081 and 156700-2411 ? Thanks a lot in advance!
[/QUOTE. had the same issue and replaced relay and fuse to no avail, pretty sure it the clockspring .
You sure the relay is bad? Recently had the dealer tell a friend that. Turned out to be the clock spring. No other symptoms.
Actually, my issue turned out to be the compressor that did not generate pressure in the system. clutch engaged and compressor did spin but high side and low side had the same pressure around 90psi when outside temp was 85-90F range.
