I went through and checked everything on my horn and magically it started working again!
Here are the steps I went through.
1. Checked the 10a fuse (good)
2. Pulled the relay and checked the connections, opened it up and everything looked brand new.
3. I removed the two side panels of the steering wheel with a small flat head screwdriver. Unscrewed the Torx bolt on both sides and popped the horn/airbag cover.
The white plug (bottom middle) is a single wire for the horn to connect to the rocker activators. (This is incorrect)
I left the yellow airbag wire plugged in. That thing made me nervous (I had the battery negative unhooked).
4. I plugged the white plug back in and started testing voltage in all the hot spots. All came back with 12v. So everything was active!?
Here are the locations.
Black Arrow: Grounding point
Top red arrow: Pin 6 (horn+) on the harness
Other red arrows: The four bolts on both left and right rockers.
5. With everything testing out ok, I plugged the battery back in and started putting the steering wheel back to together. All of a sudden, it honked! I got it all put back together and it would honk every try in all spots. There must have been a loose connection or something needed to be reseated. I basically checked, unplugged and plugged back in every component of the horn system.
Like others have said on various threads here, the horn is the most basic circuit in the car. If the relay, fuse are ok, make sure to test continuity and look for live wires with a volt meter.
