Holy mother of Voltage!!
TN
I was driving home this evening and looked down at my voltage gauge :bang: & bam!! Will definitely have to look at that within the next few days!!
Yup.. nothing wrong there.
Just seems high/inaccurate to me. But maybe I'm just used to my Fzj!! I'll meter it tomorrow just to make sure.
The gauge isn't accurate at all, dash gauges rarely are. It looks like you have a good battery and alternator netting you probably ~14V charging.
Based on the scale of the gauge, you might be 0 to 1v high. Voltmeter on clusters is misleading, probably won't get your attention until battery light comes on anyway.
Halfway between 0 and 18 is 9, halfway between 9 and 18 is 13.5, which is right where you needle is and right about where voltage should be.
No seatbelt at 75mph - booooooooo.
Easy Trunk Monkey!! I had it on, but my seatbelt light won't go off!!:bang: Lol.
Normal if you compare it to my gauge.
I just put in a brand new AGM battery and its gauge location is identical to the bad battery I replaced.
Same here. The gauge didn't change at all.
Don't worry. Toyota electrics/electronics are bulletproof. Unless on VW/Audi/Porsche cars where you look at something wrong and it fails.
Off topic: What's the green symbol in the bottom right?
EDIT: I guess I could add to the bunch and say that's right where my gauge sits as well, and it makes sense to me :)
Its just a light that is telling you your Headlights (set to auto) are on. "Headlight Indicator"
You are also part of the no D light club.
Your new-to-you LX is fitting in just right.
As for voltage: standard.
Since you just bought your truck I understand your reaction. All your senses are heightened trying to figure out if everything is cool. That is also standard.
