Holy Dipstick batman......... (1 Viewer)
DLJ
Local Stealership wants $600 to do the 90k mile service. Said would take 4hrs...so if you figure $40/hr LR that leaves you with what $440 worth of consumables.....what am I missing besides the usual clue? :slap:
Kinda tough for us to evaluate your question. Provide us with a list of what they're doing for $600 when we don't know, ya know? Heh.
DougM
It aint 40 bucks an hour anywhere.
Well, maybe at Junk's place :rolleyes:
I was very surprised when I got my '94 last year -- bought it from the original owner, a urologist, who would routinely take it to the 'yota dealer and let them do whatever they wanted -- hell, he even paid for a few simonize "clean the inside of your engine" treatments --
-- what was more disconcerting is that this guy was routinely paying $600-$900 for junk service -- tires balanced, fluids topped -- junk --
-- no cruiser-specific stuff -- no driveshaft lubes, no bearing repacks -- nothing --
-- that dealer was certainly happy though -- but they could have gotten more out of him if they talked-up the "cruiser specific" more expensive stuff --
e
Just picked mine up today from having the 90k service done at the dealership. Total bill was $360.
Here's what I think the dealers would do on 90K service (IIRC, more or less of a 30K one):
Replace Air Filter
Set Timing (where applicable)
Change Transmission Fluid
(A/T w/o type T-IV fluid)
Replace Limited Slip Differential Oil
(where applicable, add $24.95)
Replace Air Conditioning Filter
(where applicable, add $84.95)
Scope and Set Idle (where applicable)
Replace Fuel Filter (carb models only)
Clean Throttle Body/Idle Speed Control Valve
Replace Non-Platinum Spark Plugs
Drain and Refill Coolant
(type T-IV fluid add $27.95)
Change Differential Fluid (2WD models)
Inspect fuel lines, connections, tank band, & vapor vent system hoses
Cost is $289.00 here in CA.
Frank.
Sorry out of touch on the labor rate.... :doh:
This is what edmunds comes up with....;
:ban:
Part Description Part Cost
Air filter $ 19.10
Automatic transmission fluid $ 10.36
Coolant $ 12.00
Differential fluid $ 16.80
Engine oil $ 18.25
Oil filter $ 6.60
Spark plugs $ 22.80
Transfer case fluid $ 8.40
Total Estimated Parts Cost $ 114.31
Labor Action Item Labor Cost
Replace Air filter $ 2.87
Inspect Automatic transmission $ 4.78
Change Automatic transmission fluid $ 23.92
Inspect Ball joints $ 4.78
Inspect Body $ 2.39
Inspect Brake lines, hoses & connections $ 0.95
Inspect Brake system $ 19.14
Inspect Chassis nuts & bolts $ 4.78
Flush/replace Coolant $ 33.49
Change Differential fluid $ 23.92
Inspect Drive belt(s) $ 1.43
Lubricate Drive shaft $ 4.78
Change Engine oil $ 9.57
Inspect Exhaust system $ 2.39
Inspect Fuel filler cap $ 0.95
Inspect Fuel system $ 4.78
Replace Oil filter $ 4.78
Replace Spark plugs $ 33.49
Inspect Steering gearbox $ 4.78
Check/lubricate Steering knuckle $ 14.35
Inspect Steering linkage $ 4.78
Inspect Steering rack $ 4.78
Inspect Transfer case $ 4.78
Change Transfer case fluid $ 23.92
Inspect Transmission fluid $ 4.78
Clean/repack Wheel bearings, front $ 110.05
Rotate Wheels & tires $ 14.35
Total Estimated Labor Cost $ 369.88
Total Estimated Costs
Total Estimated Parts Cost For Your Area $ 114.31
Total Estimated Labor Cost For Your Area $ 369.88
Total Estimated Cost (excluding tax)* $ 484.19
*This Total Estimated Cost includes the preventive maintenance items recommended by Toyota. The facility that services your vehicle may perform different, greater, or fewer procedures that can affect the cost you incur. For example, engine oil change and filter replacement are commonly performed by dealer and independent service facilities at special prices. These "special price" services do not typically include all of the additional procedures recommended by Toyota at each service interval.
Printer Friendly Version | Get information for other cars
