Holley Sniper EFI 2300: Throttle Cable Brackets at the Carb
GA Architect
Woodstock, GA
To all who have installed the Holley Sniper 2300 units, would you mind posting up photos of how you attached the throttle cable to the carb? If you used any particular off-the-shelf brackets could you post up part numbers? Also, your thoughts either good or bad about the setup you went with.
Thanks in Advance!
Take a look at ebay #254216019493, 3rd photo, easy deal.
I have a lokar cable and bracket. works great. the yellow is heat shrink on the cable end I had to cut it and that stops the fraying.
JP
