Thanks for the tip, and yes, that's what I'm trying to do. I have never used a chain wrench so while I'm generally willing to learn new stuff, not sure removing the balancer is where I want to start (call me chicken, but...). I just see the wrench flying off and somehow setting the neighbors house on fire (given the way I usually wrench that is).
My fist time I made my own SST tool, worked, but a pain to build and use.
I was very leery of using a chain wrench until I tried it. Really this is the easiest & cheapest way, just remember to protect the belt grove of HB with old belt. You'll kick yourself and say why didn't I try this first.
My chain wrench does not fly.. LOL
It has a 2' long breaker bar with a 3/8" width chain (3/4" width if you include holding pins) $10 IIRC.
Impact wrench will spin it right off without holding as our 100 aren't that bad (tight) usually. Just need to pull radiator to get enough room for most impact wrenches, or use with a universal but that can be tricky. But this is extra work and/or $$.
The Lexus IS300 is so much harder than our 100, hard to believe on a 6 cylinder but it is. Some IS300 guys use the starter, by bracing the beaker bar on frame or floor, the turn the key. That is one I'm too chicken to try, but the IS300 guys do it all the time. Even impact wrench will not work without chain wrench and the SST tool just bends on these IS300's.
Try the chain wrench, you'll thank me. If it doesn't work take it back, but I'll bet you'll find many uses of this new toy.
Tip: The larger and longer the breaker bar the easier the job.
