Hj61 24v stereo with factory amp??
Australia
It’s my first post so go easy…
First up the car is 24v but the stereo is 12 v ran through a reducer in the engine bay.
Was attempting to get the rear speakers working today (not sure if they are factory but they are up on the gutter line in the back?) and I stumbled across another speaker in the rear on the passenger side. It looks to have a factory amp or something wired through it. Has anyone seen one of these before and know what it’s for?
PS I still can’t work out the rear speakers but it’s a fair rats nest of wiring behind the stereo. Couldn’t quite get the dash the whole way out to get full access though.
Anyone have any wisdom on what this part is? And also how to get the dash the whole way out??
Cheers
I see no one has replied here. I recently ripped the stereo out of mine. I installed a small deep cycle battery and 24v-12v converter under my driver's seat. I added a separate fuse box and am running all of my new accessories from that box.
That being said I have not even looked to see if I have a woofer mount, that is most likely what you are looking at. I am about to swap all of my speakers though.
To get the dash out you have to disconnect the spedo input. Right behind the speedometer. Heads up it is a pain in the ass to get back on.
My head unit was a complete rats nest, I dont know how many times they tried to t off the ACC line, but it was way too many. Took an hour to sort through everything. Even still I managed to swap my front and rear speaker wires. God speed and don't hesitate to hit me up with any questions.
Thanks for that
Have had some spare time and managed to get the dash out, found the rear speaker wires and and am about to solder the new stereo in.
I also managed to work out the power source for the amp using some of the original 24v wiring from the old stereo. Just wondering g if anyone knows which wire is the remote output to get the sun/speaker to work with the new 12v stereo? Or is this even possible?
Cheers
The HJ's have a small amp just for the subwoofer placed next to the subwoofer. It's not large enough to do much beyond the 5.5 factory speaker. Wiring to it is 24V and line voltage inputs (not speaker level inputs).
The OEM wiring for the head unit is interlaced with the wiring to a factory 24V to 12 converter located under the dash cap. It is weak but should be enough to power a new head unit if you aren't using the head's amplifier. The wiring is messy enough that I choose to bring in a new power source when I replaced the JDM radio.
JBL sells a 24V 60W 6 channel marine amplifier if you're upgrading your speakers.
Interesting thread, my rear subwoofer is the same.
I have the amp and there is power to it, but the sub has been removed for some reason. I'm guessing it was torn and making annoying noises.
My rear speakers still work, they don't run off the amp.
I'd love to put a new sub in but I've never been able to find one. I'm assuming they are all destroyed by now with age.
If you ever find one, or find one that would work with the little amp let me know!
Its been a while but reviving this in the hopes for some assistance. I have the HJ with the stock 24-12v converter like you said and the same stock head unit pictured above. Im trying to put a new Alpine touchscreen head unit in but i dont want to do anything else. What is the best way to simply wire in a new head unit and run it off the stock setup? Is there an adapter or wiring diagram so i can figure out how to wire in the new radio?
Id rather not eliminate the in-dash converter and go to a 24V radio since options are limited and it seems like more work than just getting the existing 12V setup to work with a normal new radio.
Reviving the previous attempt at revival. I have a similar HJ as OP 2 tone brown and fender mirrors.
I swapped out all my speakers with kickers a few years ago had to Do some slight trimming on the subwoofer bracket in the rear panel. I had a pioneer touchscreen with plug in CarPlay that worked great just presets reset every time I turned off the key. I tried a low draw step down for a constant and the switched step down for accessories. At the same time I had a killer parasitic draw so I removed everything not factory. As a previous commenter it was quite the birds nest mess. Turns out it was the rear hatch door lock actuator solenoid, now I don’t have a power lock hatch minor inconvenience. I was going to reinstall another Double DIN head unit even considered a large floating screen like alpine Halo 11” or kenwood dnr1057 (I have one in my tundra and it’s nice) but decided to go a different route.
I’m installing a Bluetooth SSV MRB2R basically a SxS stereo with a simple knob for volume and buttons to change track running off a victron 24-12 dc-dc, that will run other accessories powered by the ignition switch. I’ll get a cheapo removable CarPlay screen that runs off usb power like the Carpuride W903 mounted to a ram mount that I can easily remove and also mount my phone to for navigation. I don’t have a factory radio or else I’d leave it in for nostalgia and keep would be thief’s away since it doesn’t look “fancy.” I’ll find something to fill the hole on the dash. Maybe a blank plate to put RAM mounts and accessories or switches on.
Thanks for great topic the 24v struggle is real.
