hi guys
Just looking for ideas- I have an 87 HJ60 (24 volt) up in Ontario canada and its been bitter cold - anyhow for the last 2 yrs of ownership she has been a bugger to start in the cold.
Moreover been battling this winter- she has block heater even put new cord on it - and it works - also put an inline heater in lower rad - so she should be good to go but its not - The issue is probably a glow one - the glow plugs are NGK 14.4 vollt and were new fall 2012
what seems to be happening is my glow plug indicator light only comes on for a split second when I turn the key.
Ykes - seems to be a glow plug circuit issue - so I have checked my water sensor and its resistance seems to change with temperature hence sort of follows the graph that it should,
My relays all work - no matter I took them apart and cleaned the contacts inside the relays
I also took apart the pre heat timer box - cleaned all contacts and replaced a transistor that looked to be in rough shape - it actually had corrosion on it
I checked my resistors (on manifold) for continuity - they seem fine - no matter I took aprt and cleaned contacts
I checked my glow plug current sensor for continuity - it seemed fine - no matter cleaned up contacts
Now the voltage at the glow plug bar is low - around 6.8 volts - I believe it should be 14.4 for several seconds then drop down
so my question is this - what Am I missing that controls the length of time that the glow plugs take on full voltage (14.4 V) - My gut is thinking its something in that pre heat timer box is not right visually all resistors look good and we checked the capacitors with a testor and they seem fine
Any ideas - thanks in advance
Kent
Kent
