Here are 2 diagrams for the "evil tap" headlights in the HJ60 series.
I made 2 diagrams because I have no idea on which market model (Europe or non-Europe) Toyota made the changes.
The first one is based on the "non-Europe" diagram.
In this diagram the 12V dimmer relay is hooked up between 12V and ground.
This dimmer relay is controlled by the dimmer switch that connects to ground.
The second one is based on the "Europe" diagram.
In this diagram the 12V dimmer relay is hooked up between 12V and 24V.
This dimmer relay is controlled by another (but now a 24V) dimmer relay which is controlled by the dimmer switch to ground.
I think that this version is the real one because the wiring colors match with the colors described in the thread from Mark: -►
rewiring a stock HJ60's 12V headlights to 24V
One of these diagrams should fit your 60 series Cruiser.
Please let me know which one fits your cruiser.
The easiest way to figure out what you have is to look at your dimmer switch.
The "non-Europe" uses 4 wires (RW, RG, RY and WB) where the "Europe" uses 3 wires (RG, RY and WB).
Comments more then welcome,
Rudi
