Nice rig!
It is suposed to be Toyota Spring green T1028. I had to get it matched from a colour sample as I couldn't get it made up from the code.Great colour
Took it for a WoF yesterday and it failed on brakes. It's all new and needs to bed in but I can't drive it without a wof, can't get a wof without driving it :grrr:.....
I was out enjoying the '45 even at a reduced pace of 80ish kmh when I got attacked by a piece of road grit, it turned my clean and shiny windscreen into a blizzard of glass cubes
I had a chilly and drafty drive home and now I'm looking for a laminated screen to repace my fragmented toughened one.
At least it is just flat glass but I wanted to play this weekend for a change!
I've got to the bottom of my fuel issue, it turned out the transfer pump wasn't pumping!
The plunger had stuck in so it wasn't following the cam so no fuel pressure. the engine still ran with the injector pump elements pulling in their own fuel but as soon as the was a greater demand then the couldn't get enough to fill the pumping chamber so no more fuel was delivered. With it all freed off it goes much better
I was almost about to pull the engine and fit a 2H but I think I'll leave it with the H now. I will try to fit the 5 speed with a pto that I have but only if it will fit onto the H bellhousing as I don't want to mess with the engine mountings. If I have to fit the extra crossmember to get the box to fit then I might as well go for the 2H swap at the same time.
