I’ve been on the hunt for these for months. Finally tracked down a set for a future 12HT swap (I’m assuming that’s what you are using them for?)
I’m planning on putting them into CAD and fabbing up sets to offer up to the mud community as the mounts are becoming harder and harder to find. Not sure what your timeline is, but I’m hoping to have the first set ready to go in a month
HJ45/47 mounts are the same as early (up to 11-84) HJ60 except they do not have provision for Power Steering pump mounting.
HJ61/12HT mounts are the later (post 11-84) version with the updated P/S pump.
Close but incorrect.
I have all the mounts stashed away in case a photo is needed but unfortunately they aren’t for sale at this time.
#1 hj45 had a H diesel which is different than the 2h block and mount brackets
#2 early hj6x left side mount is what you have pictured in your first photo it is different from the hj47 mount in that it’s not incorporated into the lower alternator bracket like on an hj47. Either can be used to mount a 2h/12ht into a 40 frame but the 60 mount is ideal so you can use the 12ht upper alternator and ac bracketry.
Yes you are correct about an hj47 having a 2H engine.
2h engines had different brackets for different years and different chassis applications so, "2H brackets" is a broad statement without the necessary application information.
At least three types that I've seen...
In addition to my two photos above, I have a third set that came off a Coaster HB31 bus with 12HT . Interesting about that one is that the RH and LH engine brackets are identical.
