High/low range Transfer case and differential gearing
Frisco, CO
Figured I post the topic for discussion since it's a bit spotty throughout the 100 series forum.
My specific interest is to acquire feedback from others that not only completed the 10% under drive in their
transfer case but also converted their ring and pinion to 4.56 or 4.88; specifically anyone with the a343f/4 speed trans.
I've completed the hi and low range gear swap into my t-case along with the part-time 4wd kit. i have found i still
have a bit of gear hunting due to the extreme climbs we have here out in the CO mountains. My thought was that being
able to stay in 4th/OD would be more advantageous vs turning off OD which kicks down to 3rd and really revs out the engine.
Thoughts comments, and personal experiences welcome.
What’s your tire size?
Carrying a lot of weight?
I did the transfer case gears and I’m very happy with it even though it is still slightly under geared compared to factory. But I also have a 5 speed, more power (‘07), my 34.5” wheels/tires are relatively light and I’m weight conscious overall. It drives very well, even through the mountains.
Guess i should have mentioned that I'm on 35's.
The 10% under drive has been a decent improvement by itself, but was seriously thinking of changing out the
ring and pinion to 4.88's. I need to open the front anyways and thought of doing a locker and gears at the same time.
So you're still a bit under geared as well, probably by about 3% if your 35's are true to size. 4.88's will be a big jump, 13.5%. It will definitely get out of the hole faster and hold top gear easier but might be a bit buzzy at highway speeds. There are others running that combo but gearing is a very subjective matter that depends on a lot of factors.
Holding 4th and not having to run near full throttle or turn-off O/D is what I'm after. The 3rd gear ratio is 1:1 where 4th is .75. I figured that the 4.88
gearing would allow me to keep the rpm's needed to climb these CO mountains comfortably at 60-65 mph while holding 4th.
I'd recommend playing around with a gearing calculator. 4.88's with the 10% under drive on 37's would actually be over geared. On 35's it will be fairly aggressive compared to stock.
If he were to go to 4.88s and main downside is that at highway speeds his rpms are high (probably pushing 2.5k/3k at 70 mph), is the main concern the noise and high whine from the rpms? Or is running at that rpm putting too much stress on the transmission and engine?
I have been thru all the gear/rpm calcs and the problem is that these can't take into account or simulate the load applied on steep grades.
The current 10% under drive with the stock 4.30's is actually very nice. However, I am finding that these 3-4 mile 5-6% climbs are still
causing a lot of stress due to having to run with O/D off which is dropping into 3rd (1:1 trans ratio). If there were just a few climbs and were short I'd not worry about it.
Heres what I came up with;
10% UD w/ 4.30 r/p (e/r = 4.73) , O/D OFF = 1:1 trans ratio equals ~ 2750 rpm @ 60 mph.
10% UD w/ 4.88 r/p (e/r = 5.30), O/D ON = .75:1 trans ratio equals ~ 2300 @ 60 mph ( with O/D off equals ~ 3000 rpm @ 60 mph)
