High compression in a 3FE
Northern California
Anyone running higher compression in their 3FE? If so did you add a engine oil cooler? Did you get the ECU reprogrammed? Has anyone tried to pass smog with that setup??
Andrew
88' FJ-62
97' FZJ-80
01' Tacoma
You might give the guys at Man-A-Fre a call. I know they've done some work with the 2F motor and upping compression to 9 or 9.5 to 1. IIRC it give a great deal more power, but you have to run premium gas to keep the detonation issues at bay.
-H-
fj62's have a stock oil cooler. Steve Crase is running a shaved head on his 3fe, he likes it but it needs premium.
