High beam light issue - update
Netherlands
Hi gang,
My normal head lights are working ok.
my high beam works when pushing the handle to the back, but no blue light indicator
my flash high beam is NOT working
Where to start looking?
Got the switch out
saw good how it functions
cleaned the connectors, no improvement
found out that 1 wire (RY) had no power
behind the gauge console was a lose connector
no sign of the other connector
update 1
the b/w wire from the high beam handle is not connected
I found some more lose ends
its a mess :(
I'm starting to think its all connecting:
Blue high beam not working
Flash high beam not working
When head lights on, the fixed high beam is working, but no blue light indicator gauge console
update 2
Found the red wire in the harnass cut off
Now how to make the connection between the red wire and the HF part, what is the color of this wire in the dimmer switch?
thx indeed
yes I was seeing this and also the handle wire diagram
I did 'shake' the wire harnas coming out the handle
I let the handle 'plop' to make sure that there is good contact
If I put on high beam the headlight goes out on both ways
Maybe with some cleaning fluid or fine sand paper?
You should mark and pull the wheel and clean the switch, or cycle the handle a bunch in hopes to clean the contacts. The bulb in the cluster might be bad. Be sure to disconnect the battery if you remove the cluster. There is no flash function that I'm aware of.
View attachment 4108671View attachment 4108672
nice job :)
yeah, flasher high beam is not working, and main head lights go out when flashing high beam
Contacts handle are fine
So power on fixed High beam is there, but no power for flash high beam
nice job :)
