WTITW
- Joined
- Feb 13, 2020
- Threads
- 90
- Messages
- 725
- Location
- Chandler, AZ
- Website
- www.wastingtimeinthewoods.com
Anybody replace hid’s lately? These look like the two most reputable on amazon. Anyone have experience?
Diode dynamics or Philips?ordered the same
Philips.Diode dynamics or Philips?
Diode Dynamics is at least partially M-USA. They have a large facility here in the St. Louis area. I'm tired of cheap Amazon LEDs crapping out and will be swapping most of my bulbs over to their stuff.
The DD reverse bulbs are great. The OE reverse lights on the 14+ are basically enough to light up behind the reverse camera. Once I moved my rear camera up into the spoiler they became useless so I switched to the DD bulbs. They not only work for the camera but you can even look out of rear window and see things with your own eyes.For headlights I replaced the OEM lights with Attica headlights for an updated look. But for all interior lights I replaced factory with Diode Dynamics. Not the full white harsh light but in the middle of the spectrum still white but not as harsh. Except for the top rear over the attic rack.
I too got tired of the cheap made in China LED's in my Taco and have sworn off them. First thing noticed with the DD bulbs is that there is no polarity they work no matter the orientation. That was a wakeup call for me.
Last ones I have to do are the backup lights but the ones I want are spendy waiting on them to go on sale. They offer 3 brightness ranges and of course I want the brightest XPR (720 lumens) which people say are as bright as headlights. People behind may not like it when I backup but I'm not too concerned. In the woods I want to see behind me when I put it in R.
I've had mixed luck with LED headlights. The LED's I tried on Jill's 3rd gen were nowhere near as bright as the projector HID's I eventually retrofitted, but the LED's were just in the housing without projectors installed so maybe they would work better in a projector lens? I'll probably just stick with HID's for the low beams but maybe consider LED for the DRL and high beam halogen replacements when they go out.Are there LED options besides HID?
Those are sexy but they I haven't found any aftermarket housings for 10-13's. Mine are cloudy AF again after restoring a year or two ago so I need to do something. I'll probably have to do the ali-express lens replacements eventually. I'm a bit too cheap to spend $500 replacing the whole housing and a bit worried about how the AFS system will work with after market.For headlights I replaced the OEM lights with Attica headlights
Yeah, I saw those. $99/set is kind of crazy. I got the 9.99 Amazon specials that claim to be 520lumens so I'll let you know how they work out. FWIW, the cheap LED's have gotten a lot better. I replaced all my interior bulbs with Amazon special LED's when I got the truck four years ago and haven't had a single flicker failure.Last ones I have to do are the backup lights but the ones I want are spendy
Copy that but these are Xenon HID. Not as easy to mass produce as an emitter on a PCB, so sources are often rebranded.Diode Dynamics is at least partially M-USA. They have a large facility here in the St. Louis area. I'm tired of cheap Amazon LEDs crapping out and will be swapping most of my bulbs over to their stuff..
Save your lenses! Before and after.I've had mixed luck with LED headlights. The LED's I tried on Jill's 3rd gen were nowhere near as bright as the projector HID's I eventually retrofitted, but the LED's were just in the housing without projectors installed so maybe they would work better in a projector lens? I'll probably just stick with HID's for the low beams but maybe consider LED for the DRL and high beam halogen replacements when they go out.
Did that about 2.5 years ago. Now they’re just as bad as they were. Guess I could try again but mine have a lot of spider cracks so I thought changing the lenses would last longer.Save your lenses!
Not sure. A friend who had been in the area made the observation but couldnt recall whether it was a 120 or 150, so I may be looking for something that isn't.Did that about 2.5 years ago. Now they’re just as bad as they were. Guess I could try again but mine have a lot of spider cracks so I thought changing the lenses would last longer.
Did they use glass on the same housing for JDM/RUS models? Seems like it would be hard to form the glass for the projector pop outs.
Cerakote has a kit I'm really impressed with, but I'm not 2.5 years into, either...Did that about 2.5 years ago. Now they’re just as bad as they were. Guess I could try again but mine have a lot of spider cracks so I thought changing the lenses would last longer.
I love to see the old Sekonic in use! What's the exposure speed for ISO50 at F-22?I installed my "Amazon's choice" back-up lights today (921 LED). Used a light meter and found a 3.5x increase over the halogen, much better than the claimed 2x. That could be becuase the LED's are more directional than the halogens were. Pretty darn good for $10. Hopefully they last and don't flicker.View attachment 3726361
I was going to reply with "someone takes pictures" but missed the chance.I love to see the old Sekonic in use! What's the exposure speed for ISO50 at F-22?
For a slightly more serious contribution, I used Diode Dynamics back in 2011 or '12 for both my (now) wife's Integra as well as my SVX. Out of the 6 bulbs purchased, 2 came with bad ballasts and one bulb died within a year. A lot can change over a dozen plus years, but I'd probably still go with Phillips. My old Phillips Sonicare toothbrush is about that age and still runs like a champ.
I love the improvement for reverse lights and might follow your lead on those.
I just went back to check. Homie has it in film mode. One pic at 24fps, one at 30. He's measuring lumens, so it doesn't really matter, but maybe this YouTuber isn't such an idiot after all and cares about his craft.I was going to reply with "someone takes pictures" but missed the chance.![]()
