It will bolt up but you'd need a new rear driveshaft.From what I found out the 1991 and 1992 share the same transfer case if I'm mistaken. The 1993-97 is a different unit
Not correct. The 91-92 does not have the vicious couplerIt will bolt up but you'd need a new rear driveshaft.
Did you read what I said? It will bolt up but you need to swap the rear driveshaft. Because the 91/92 TC does not have the viscous coupler it is shorter and will require a shorter driveshaft if you use a 93-97 with the Viscious Coupler because the TC is longer. I know because I'm running this set up.Not correct. The 91-92 does not have the vicious coupler
I think you are right. My application doesn't have stock exhaust.In addition to shorter driveshaft, exhaust would need modification I believe. If I recall, exhaust runs across the back of the t-case in the 91-92. Longer 93-97 with VC would foul stock exhaust.
Not reallyDid you read what I said? It will bolt up but you need to swap the rear driveshaft. Because the 91/92 TC does not have the viscous coupler it is shorter and will require a shorter driveshaft if you use a 93-97 with the Viscious Coupler because the TC is longer. I know because I'm running this set up.
Where are you located?I need a hf2a transfer case for my 1991 any help would be greatly appreciated it is my daily driver.
I live on5 WisconsinWhere are you located?
I have one available in oregon from a 1991 fj80.
I live in WisconsinI live on5 Wisconsin
