Wanted HF1A Part Time Transfer Case (1 Viewer)
Calgary, AB
  1. 80 Series
  2. 100 Series
Hello,
I am looking for a 70/100 series Part Time Transfer Case HF1A either with low milage or brand new OEM. I'm struggling to find new OEM as most of the P/N seem to be discontinued...
Anyone will to sell or know a reliable source?
I was able to source 36120-60520 from Megazip in the past. It looks like Partsouq has one 35120-60510 in stock which appears to be a supercession.
Stedman has all the part numbers to build the shifter like Legos...I built 4 of them with his help.
Do you have a photo of 36120-60520 by any chance? Unfortunately I need one that is compatible with the 100 series, which requires the square shifter mount on the casing (which I believe Toyota deleted on later 70 series T cases...)
Nick,
I have a couple of different cases apparently. I have a 36120-60351 from Partsouq, but no shifter mount.
I wonder if you can mix and match case sections like from a 100 series HF2a - use the center case with the shifter mount and the rest of the native 70 series HF1a. @Mr Cimarron did this with converting full manual HF1a to electrically shifter HF1a.
100 series case from HDJ100.
70 series case. 36120-60351.
Looking up GCC spec FZJ100's....could you use a center case section 36036-60290? Partsouq has 4...but no pictures.
