Hex die lug crimpers?
iptman
Northern VA
Anyone in the club have a hex die crimping tool? I have about 20 lugs I need to crimp on 1/0 and 6 AWG cable.. Trying to finish everything prior to GSMTR. Time moves quickly when working to a deadline.
-Patrick
I don't have the hex ones, but i have a pair of HB ratcheting crimpers you can use if you want. They work fairly well.
this one
http://www.harborfreight.com/ratcheting-crimping-tool-97420.html
I usually just use my lineman pliers and solder anything lower gauge than 12.
***edit***
Just saw that you are working w/ 1gauge too. For this size why not just use a chisel and solder?
I bought one of those anvil type crimpers that you whack with a hammer but after watching on YouTube what the inside of a good hex crimp looks like I figured l'd throw the question out there.
If no one has one I may pick one up and throw it in to the loaner tools pool for the club after I'm done. I figure I'm not the only one left to wire up a winch or second battery.
For 6ga to 1/0 I use a propane or acetylene torch and solder. Make a solder plug, stick it in the lug, heat it (flux wire and lug, of course) and insert the wire into the lug. Easy peasy.
pm "Emorth"
He's local in Burke and the resident Electro-Man
I could certainly use some of those hex crimps if you do decide to buy a pair and loan them out to the club.
Last time I checked they were a $100 plus type of tool.
if you go the solder route I believe that Autozone carries these. The Burke Auto Parts might have them.
I watched a U-tube vido where the guy used a larged vise to compress the hammer type crimper instead of whacking. Seemed to work pretty well.
I usually crimp before solder incase the somthing shorts. Battery cables can get pretty hot.
This is the youtube video I watched that showed what a good hex crimp looks like on the inside. Look at around 1:40.
https://www.youtube.com/watch?v=3qYZFxQ8Pxw
Of course this is probably a $1000+ crimper but still.
Just so everyone knows, I did end up buying a hex crimper off fleabay. Worked great though and I'm willing to loan it out to club members if they need it. Just let me know.
Just so everyone knows, I did end up buying a hex crimper .. and I'm willing to loan it out to club members if they need it. Just let me know.
Patrick,
I have some winch cables to fab, would love to borrow the crimper. Any chance you will make it to the meeting on June 5?
