Here’s a dumb one?
texas
After tearing apart the front end for some seal work and going back together, my left side headlamps won’t work. Both but the corner light works. I chased wires and everything seems fine, no pinching or disconnections etc.
I’m assuming both sides run on the same fuse and nothing else is inoperable. Any ideas?
I thought it was going to be a picture of me driving down the road below the speed limit. Phew, dodged that bullet. Grounds! Report back!
Both grounds connected (inner fender L/R)?
Edit: beat me to it
Thanks. I’ll check. I know the one is connected but didn’t know there was two? Is it one for each side? And does the corner/blinker run in the same harness? Doesn’t look like it.
All grounds connected, both. Linker isn’t working as it’s on the same harness. There’s no issues with the harness so am scratching CB in my head?
Separate fuses for left and right headlights, both sides run off the same relay.
Low beams grounded to the inner fenders, high beams are a switched ground through the stalk.
Separate circuits for marker lamps and headlights.
