Hi, folks. I'm new here (or new after a long time away). I've got a new-to-me 1976 fj40 that I've been working on (pictured).
Lately I've been chasing wiring issues and have most of them sorted out, but here's one I can't figure out: my blinkers are not working at all, and best I can tell the relay works (at least it does show voltage on both sides with the switch on). I disassembled and cleaned the switch and connections, and that got my high beams working again. But I can't figure out the wiring. The horn and headlights go together into one clip (that clip has four slots but only three wires on each side; the headlights work; the horn does not, but that may be the relay; I haven't gotten to that yet). I also have six wires from the switch going into a clip with male ends on the switch side, plus a seventh wire with a rounded male end that doesn't go into the clip and wasn't connected to anything. I can't figure out where it is supposed to go, and haven't found a matching female end anywhere under the dash for that wire. Even more confusing, the other half of the plastic connector clip, the part coming from the truck rather than the switch, only contains four female ends (it has six slots but two are empty). One of these is getting 12 volts from the car. I've added a few pics, for whatever they are worth. It doesn't LOOK like wires are missing from that clip, though the clip is in poor condition.
I have the Toyota repair manual and have stared at their diagram until my eyes bleed but can't understand it. I do see that the brake light stop switch is supposed to be in the mix here. My brake lights work, for whatever that is worth.
Can anyone give some guidance about the seven male wires and only four female wires problem? Thanks a lot!
