Got a narrowed 14b a while back off Lowtideride. Copied Fred's 40's 6 lug hub conversion.
Couple pics of the issue I'm having w/ the pass. side rear axle shaft.
It's binding when I tighten the axle bolts down. If I leave approx. .050 gap It'll spin ok. This is on the side we shortened but neither Al nor I can recall there being an issue with binding on mockup after final cutting and welding.
If there's not something I'm overlooking I can see 3 possible fixes.
1. Shim it
2. Trim it
3. Mini spool?
I'm leaning towards option 1 now as I don't want to trim the axle shaft if it's not necessary and I don't have the $$ for a mini spool at the moment. I am also wondering whether the mini spool will allow the axle shaft to seat in farther I think it eliminates the center section of the spiders ( where the pin would be on a cruiser diff ). Any info/advice appreciated. Thanks, Jeremy
1. Shim it
2. Trim it
3. Mini spool?
