Problem
Currently stuck in park, can go into gears when I press the button on side. But when I return to park I hear a grind.
Link Thru the gears And then can't come out again except for button
All light (P R N D. Have a red light nextonthen by the shifter )
center diff is not on . Im in 4H hi. I move into 4 lo and N no issue.
This happened after I removed the front driveshaft of the 4 bolts holding it. I put it back w/o removing anything else . I spun the wheel while accessing the bolts with it in P and the parking brake on .
Both front wheel spin non-issue
The front driveshaft spins no issue except for a small barely noticeable le vibration when I switch the rotation on the driveshaft
