This is a follow up to my "Intake plenum is off..." thread earlier this week:
Well, I did it. I was replacing the valve cover. I bought a $20 torque wrench from Harbor Freight, looked up the torque settings in the Haynes manual. Nothing for 1FZFE, but the other two engines listed said 78 ft/lbs, probably alright. I tested the torque wrench at 30 and 40 ft/lbs to make sure it clicked. Seemed to work. I set to work on the hardest bolt first, the one under the heater hoses on the drivers side by the firewall. Things were going pretty good...seems like it should have clicked by now...SNAP! I sheared the bolt in the head at the hardest stinkin' place to get it out of!!! I am so mad! I moped for several minutes, thought I must have screwed up, so I took the torque wrench to the bolt at the very front of the engine, easy to drill out if it shears. Started torqueing, no click. Reset the wrench to under 50lbs...two turns and SNAP! Sheared that one off too.
Any suggestions on how to get the bolt out of the head without pulling the head or the engine?
I seem calm, but I went about 15 rounds with the punching bag in the basement and yelled at the kids, so I'm in the mad-calm stage now.
Lucy said:...To be honest I am an oil changin' alternator replacin' fool but when it gets much more complicated than that, I tend to break things.
