Hi all,
I have a quirk with my '02 hundy that is driving me bonkers. When I bought the vehicle 5 years ago it had an aftermarket DVD player in the 2nd row roof. It was ugly and the drive was burnt out, so I pulled it and bought an OEM light to replace it (part #81260-60070). When I went to install it, the original wires coming out of the headliner had been clipped (no connector), so I cut the connector off the new part and crimped black to black, green to green, red to red (with a little extra wire spliced in for length). All good, right?
Problem is, when the switch is in the door position, the light does not come on when the door is opened. With the light in the on position, it lights up fine and the courtesy lights work individually. The off position turns the light off. Since it had power, I immediately ruled out the fuse (plus I checked it anyway and it was fine). My next thought was maybe it was a relay or something. However, the third row lamp comes on fine with either rear door open, as does the "door open" indicator in the instrument cluster. All I can think is that I wired it wrong and the colors on the incoming wires and the lamp itself do not match up like for like.
Last thing I would say is that the PO of this vehicle seemed to have a lot of accessories (remote start, DVD player, satellite radio, cell charger, etc.). The wiring under the kick panel has been modified and given how many wires are down there to begin with, I can't make heads or tails of it. While I have been able to remove all the non-working accessories at this point, I am hesitant to start un-taping wires and risk screwing something up that works today, especially when that wiring may be unrelated to my issue. I have looked at all the wiring diagrams and the TIS info on this topic, but none of it has helped.
Apart from this annoying me, my wife and I are expecting our first child and the extra light sure would help back there. Below is a picture of how I wired the light. Any help is appreciated, and if someone is willing to take a picture of how a stock light is wired I would be most grateful (it's easy to access...the plastic cover pops up and 4 phillips head screws hold the base in place).
Thanks all!
NicB
Thanks all!
NicB
