Duane
IH8MUD Wookie
I have a college student staying with me that has a 1993 Ford Sable. The rear brake linings are done so i bought a new set. Trouble is I can't seem to get the piston pushed back into the caliper to be able to get the clearance to install the new pads.
This rear rotor setup has a park brake cable that pulls a lever with a shaft going into the same end of the caliper where the oil line goes.
Is there some trick to getting the piston to retract?
I used the normal water pump pliers, lever and even a big c-clamp without any luck. Is there some mechanism that ratchets inside to take up the travel as the pads wear?
Thanks
Thanks
